new mass air sensor now have code 43 AND RUNS WORSE!!
Old Jan 6, 2010 | 09:10 AM
oonighttrain's Avatar
my 87 5 speed 305 tpi 5 SPEED had a check engine light. buddy who is a mechanic says the code says it needs a new mass air flow sensor.. put one in and the car runs 100 times worse than it did before. and now it has a code 43.. he put a new cap and rotor on as well as the module under the cap..
any help would be greatly appreciated.. thanks!
Old Jan 6, 2010 | 09:17 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: new mass air sensor now have code 43 AND RUNS WORSE!!
Check the wiring to the MAF and check the MAF power relay and the MAF burnoff relay. The relay's are located on the drivers side next to the brake booster. the MAF burnoff relay is prone to failure.
Old Jan 6, 2010 | 09:25 AM
the weird thing is that it ran 100 times better with the old mass air sensor in it.. with the old mass ir it would just try t o die when 1st started. it ran smooth afetr that.. now it will die when not on the gas and pops and spits and hesitates..
Old Jan 6, 2010 | 09:35 AM
battman's Avatar
I would put the old sensor back on, Why did you replace the MAF in the first place?
Old Jan 6, 2010 | 09:38 AM
check engine light was on and my buddy (mechanic) said thats the code it had..
Old Jan 6, 2010 | 09:47 AM
buddy is telling me to try to find a new electronic spark control module??
Old Jan 6, 2010 | 11:02 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
my 89 has the same prob right now..won't ilde unless I hold the gas alil,if I don't it just dies right after kicking on..but I got codes for 21,33,45...starting wit the TPS first to check the voltage on it...
Old Jan 6, 2010 | 11:38 AM
battman's Avatar
Sounds like your buddy is more of a parts swapper than a mechanic, He already had you waste money on a unneeded MAF. change the relay's mentioned above then reset the ECM. This will usually fix the MAF codes you are getting. also look for simple things that could cause vacuum leaks and cause your problems.
Old Jan 6, 2010 | 12:27 PM
snap on 2500 scanner the old mass air flow sensor was reading 10/90 inches at idle.. new sensor is reading 28/28 at idle
Old Jan 6, 2010 | 01:01 PM
battman's Avatar
A bad burn off relay would cause your old sensor to give a low flow reading like that, If its not working it will not burn the contaminates off the wire element for proper readings.
Here are some other threads to look at:
https://www.thirdgen.org/forums/tpi/...ll-please.html
https://www.thirdgen.org/forums/tpi/...uble-code.html
https://www.thirdgen.org/forums/dfi-...s-12-33-a.html
Do a search for MAF problem and you will get lots of info, the subject has been beaten to death on this site.
Old Jan 6, 2010 | 04:48 PM
tried a replacement mas.. same results as the other new one.. i ordered the 2 relays.. wont be here for 3 days..
Old Jan 6, 2010 | 06:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Code 43 is the Electronic Spark Control (ESC). I think that is the elctronic unit that is located under the distributor cap. Remove the cap, and remove the ESC unit, should be two small screws if I remember correctly. Take the unit down to a parts store and have it checked. Make sure that they test it 10 consecutive times, because sometimes a bad unit will check out good when its cool. I have had these ESC units go bad with the car just sitting around or the dizzy sitting on the shelf waiting for an engine change!
Old Jan 6, 2010 | 09:55 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'm no mechanic. But that code 43 is pretty common when an engine is running like crap. It's a result, not a cause usually. Unplug the MAF and see how the engine runs on default. Rule out the MAF circuit. Check fuel pressure yet? If not, do that next.
Old Jan 7, 2010 | 07:25 AM
put in a new esc also.. i still dont understand why the car runs 100 times better with the old mass air flow sensor than a new one..
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
