What Size Belt Will Fit?
Old Jan 10, 2010 | 12:50 PM
BigLou907's Avatar
Car: Camaro RS
Transmission: Automatic
Axle/Gears: Not Posi :(
I have a 91 RS TBI with a serpentine belt and I was wondering what belt size will fit with out the Smog or A.I.R pump pulley, i still have the AC, water pump, alternator, power steering, and crank pulley. What size belt would I need just w/o the A.I.R Smog pulley?
Old Jan 10, 2010 | 02:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What Size Belt Will Fit?
There's a tech article off the main page - it states a size but that size didn't work for me when I did mine - just measure with a string then go to parts store and get that size.
Old Jan 11, 2010 | 12:39 PM
BigLou907's Avatar
Car: Camaro RS
thanks i saw the 96.8 size belt is what their telling me do you know what size you used? and is that with or without out the delete pulley?
Old Jan 11, 2010 | 11:52 PM
Car: 1992 RS
Engine: Carbed 350
It's been 2 cars ago, so I don't remember. But the .8 I never understood, as they come in even inch sizes and 1/2 inch sizes, so you'd either have to get a 96.0 or a 96.5 for example. But if you buy one and it doesn't fit, they'll take them back for exchange - or do the string trick.
Old Jan 13, 2010 | 12:07 PM
BigLou907's Avatar
Car: Camaro RS
alright ill try the belt or belts (if I have to) and will try and let you know my results it i wish i understood how to jus take off the whole pump and disable the whole AIR system ive read threads about it but i didnt fully understand what they were talking about but im sure when i get down in there everything will be fully understood or will make sence then thanks again
Lou
Old Jan 13, 2010 | 02:44 PM
Car: 1992 RS
Engine: Carbed 350
Just take it off. Just take the pump off the bracket, and remove the hard lines from the pump, then remove the plastic box. Then, you go get threaded plugs from any hardware store to replace the check valves on top of the exhaust manifolds, and plug the tube from the cat converter, and you're done.
https://www.thirdgen.org/serpentine
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
