misfire at idle
Old Jan 11, 2010 | 10:45 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
misfire at idle
ok my car is pissing me off. it has new plugs, wires, accel cap and rotor, timing has been set to specs, and it has a brand new fuel pump, fuel filter, and injectors. and it only misfires when the engine warms up. going down the road is fine and it runs on all 8. i tested the ignition module 10 times and it is ok. im stumped. any suggestions on what else to look at?
Old Jan 12, 2010 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you done a compression test?
Old Jan 12, 2010 | 10:57 PM
Car: 1990 Trans Am
Re: misfire at idle
no i havnt yet. i have kind of been ruling that out cuz the engine only has 45000 miles on it but i will check it see if it will tell any secrets.
junior419
Apr 7, 2025 11:35 AM
camarohelp
Sep 22, 2015 03:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
