081s vs S/R 58cc
Old Jan 13, 2010 | 09:18 AM
chcgobearsfan3's Avatar
Car: 90 camaro RS
081s vs S/R 58cc
Would it be more cost effective to have the 081s worked or buy a pair of bare S/R? What kind of flow could a first timer get out of the 081s, sticking with 1.84/1.5? If it's cheaper to get the 081s worked, does anyone in the chicago area know of a place that does a good job for decent prices? Site or # would be great, thanks.
Old Jan 13, 2010 | 09:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The S/R's will need some work, at least in the bowl area. World leaves them pretty rough.
But, they already have 1.94" intake valves, screw-in rocker studs, and typically a little better casting quality.
Old Jan 13, 2010 | 10:05 AM
Car: 90 camaro RS
Re: 081s vs S/R 58cc
Well if work will be required either way, how hard is it for a first timer to do? I'm looking for maybe 215 cfm @ .450, up from the 186 stock.
Old Jan 13, 2010 | 12:44 PM
five7kid's Avatar
When I ported mine, it was the first set I had done. I followed the Standard Abrasives Do It Yourself Porting Guidelines, practiced on one cylinder worth of a stock head. You probably don't need to do everything they show (such as gasket matching), but the bowl area benefits greatly from their suggestions. I don't have flow numbers, however.
The things I'd do differently would be using carbide burrs for the major material removals instead of all sanding rolls, and "airfoiling" the guides.
TexasMaro
Sep 15, 2015 06:50 PM
MattW
Aftermarket Product Review
Jul 18, 2001 12:13 AM
camaro6spd
Apr 20, 2001 08:49 AM
danzig27
Mar 14, 2001 08:21 AM
DANIELEK
Dec 24, 2000 07:02 PM
