Mechanic Potential Scam! Need help asap.
Old Jan 14, 2010 | 06:15 PM
goDJ91's Avatar
Car: '91 Firebird
Engine: 3.1L V6
Transmission: Standard
Axle/Gears: Stock
I just had a rear pinion seal replacement and a rear differential seal replacement by a mechanic shop. 1 day later while cruising on the freeway at low rpms going around 65mph I hear a pop and the rear differential area had sprayed out oil onto my exhaust piping.
Did the shop who did this work do something improperly and are at fault for this? Or is it likely they did it wrong to cause my pinion bearings to go bad the way they did?
Need advice/answers/questions asap. Thanks.
Old Jan 14, 2010 | 06:16 PM
goDJ91's Avatar
Car: '91 Firebird
Engine: 3.1L V6
Axle/Gears: Stock
Re: Mechanic Potential Scam! Need help asap.
Also, I am on AIM at Djacobsone
Send an IM for more details or to give me your thoughts on this issue.
I'd prefer AIM for quicker response and a more thorough explanation of this situation. Thanks again.
Old Jan 14, 2010 | 06:41 PM
goDJ91's Avatar
Car: '91 Firebird
Engine: 3.1L V6
Axle/Gears: Stock
bump to top
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
