L31 Fuel pump lobe?
Old Jan 15, 2010 | 11:59 PM
wheeliE-maxx's Avatar
L31 Fuel pump lobe?
I was thinking about getting the 3/4-1 ton truck version (4-bolt, better exhaust seats) of an l31 Goodwrench crate engine. http://sdpc2000.com/details/gm-goodw...gines/12530283 My question is whether or not the cam has a fuel pump lobe? Will I want to use a bronze tipped pump push rod, and what kind of distributor gear for the roller cam?
Old Jan 16, 2010 | 11:44 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: L31 Fuel pump lobe?
call the tech line 1-806-798-4108
we did not build the motor
Old Jan 16, 2010 | 01:08 PM
The question is do late model roller cams typically have the fuel pump lobe. This is the same cam as the lt1 y-bodies. What about l98 cams?
Old Jan 16, 2010 | 07:51 PM
one92rs's Avatar
Car: SOLD!!!!!
no it does not as the later model gm products used electric fuel pumps.
Old Jan 16, 2010 | 09:48 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Some of the cams Do have the fuel pump lobe, but not all of them you would have to get info on your cam. Also the L31 does not have the fuel pump rod hole drilled completely out, but it only has the castings left at the back of the hole. So you could drill it the rest of the way if needed.
Old Jan 16, 2010 | 11:12 PM
Aww, this sucks. Was hoping to use my new original style steel fuel line that works perfectly with the q-jet. I could run an electric pump, but for the price i'm just better off with the Year One 350
Old Jan 17, 2010 | 02:35 PM
one92rs's Avatar
Car: SOLD!!!!!
yes some cams have them. but the cams for the l31 truck vortec engine do not.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
