rocker nuts
Old Jan 21, 2010 | 05:25 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
rocker nuts
Hi,
How to secure rocker nuts. I tried to use red thread lock, but after 1K miles some nuts became lose.
here is my project camaro almost done.
Old Jan 21, 2010 | 05:30 AM
Car: Camaro LT
Re: rocker nuts
Sorry almost forgot..
It is chevy small block 305 stock reworked heads but still with pressed in studs.
Old Jan 21, 2010 | 06:03 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: rocker nuts
I fthey are loosening w/ blue threadlok, replace them...
Old Jan 21, 2010 | 06:14 AM
Car: Camaro LT
Re: rocker nuts
red threadlock is stronger then blue and I already used new nuts.
Old Jan 21, 2010 | 06:22 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: rocker nuts
mine kept backing off on my old 355, I ended up just buying a box of nuts from the hardware store and adding a jamb nut to the tops of all the studs. Never had a problem again.
Old Jan 21, 2010 | 09:57 AM
Car: Camaro LT
Re: rocker nuts
There is not enough space for a jamb nut.
I thing about try to use "liquid metal"
Old Jan 21, 2010 | 11:31 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: rocker nuts
I've never had that problem with new nuts.
Old Jan 21, 2010 | 02:14 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: rocker nuts
What kind of rockers are you using? Using stock pressed-in studs? Screw-in studs? With stock rockers + studs, theres enough room for jamb nuts. Unless the threads on the stock studs are really worn, a new set of stock rocker nuts from GM, comp cams, or similar shouldn't need threadlock. With all the oil, the threadlock is nearly useless there, anyway.
Old Jan 21, 2010 | 02:19 PM
50bmgshooter's Avatar
Re: rocker nuts
dont use that or anything like it. you wont be able to readjust your valves later if you need to.
you could try nylon lock nuts or a set of posi locks for roller rockers
what i would do if i was you is pull your heads off and have the studs replaced because that is were your problem would be if you got new lock nuts and they back off.
Old Jan 21, 2010 | 04:07 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: rocker nuts
What holds the torque on stock nuts is the oblong shape (as opposed to round) at the top area of the nuts.
After several tightening/loosening/re-tightening the oblong shape gets rounded out. After that happens they can loosen. If that's what's happening a new set of nuts will solve your problem. They're inexpensive and available at most auto parts stores.
However, press-in studs are known to begin to get pulled out over time, especially when higher pressure springs are installed and/or repeated high RPMs are used. GM probably moved away from press-in studs for that reason.
If that's is happening, the heads should be pulled. The least expensive fix is to have a machine shop pin the studs. Best way, though, is to have the stock studs pulled and the stud holes tapped for screw in studs.
Tapping has been done with the heads installed on the block, but there'll be a lot of shavings to be concerned about. I don't recommend doing them that way.
Jake
Old Jan 22, 2010 | 11:21 AM
Car: Camaro LT
Re: rocker nuts
Stamped steel with roller tip rockers. studs are stock pressed in.
heads are resurfaced and shaved down by 0.7mm to rise up compression. therefore there is no space for jamb nut.
I think nylon is not the best locking material for high temperatures.
Yes, I have stronger springs because of cam change. and my engine quite often sees high revs, however there is no problem with studs.
will try to use new nuts and "lock tight"
thanks for your replays..
Old Jan 22, 2010 | 12:24 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: rocker nuts
shaving the heads by .7mm should not affect how the rockers attach. they shave the bottom of the head.
did they lower the spring pocket by .7 ??
Old Jan 22, 2010 | 01:35 PM
Car: Camaro LT
Re: rocker nuts
No.
What would be the reason doing so? this will increase installed height reducing spring pressure . which will result in valve float... I use quite aggressive comp's 08-412-8 camshaft.
Old Jan 22, 2010 | 02:09 PM
Engine: L98 494hp
Re: rocker nuts
the comp cams specs on that says that head machining required. You would of had to machine the spring pockets to have the correct installed height probably. Did you measure the installed height of your springs??? That's more lift than ususally is good on stock heads.....495 lift is what I found. What is your installed height, and what does your springs call for??
Old Jan 23, 2010 | 02:57 AM
Car: Camaro LT
Re: rocker nuts
the only thing i did to accept gross valve lift I trimmed valve guide a little so there is 1mm space between retainer keeper and valve guide at max lift.
Springs where the same as stock except stiffness.
There is no problem with valves, or rocker geometry, or any related ... the only problem is rocker nuts.
Old Jan 23, 2010 | 03:07 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: rocker nuts
I think JakeJr might be onto something suggesting the studs might be pulling out. Put a straight edge along the tops of the studs and see if any don't touch the straight edge, then you'll know.
91interceptorZ is also correct in saying that shaving the heads will have zero effect on the studs. If you're using stock replacement nuts there should be more than enough room for a jam nut on top of the rocker nut.
Old Jan 23, 2010 | 10:32 AM
JakeJr's Avatar
Axle/Gears: 3.07
Re: rocker nuts
I certainly hope you're right because if you're not . . . . .
Jake
Old Jan 24, 2010 | 12:33 AM
Engine: L98 494hp
Re: rocker nuts
you do need to measure the installed height of the spring and such.....there should be no fitment issues. Checking the studs as well is a good idea, they might be pulling out.... Something is NOT right, it for sure should not be like this. Something is not measured correctly, or coming apart. Need to figure out before it damages something badly. good luck.
gord327
Sep 29, 2015 10:18 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
3.8TransAM
Sep 27, 2015 08:37 PM
Fox118
Sep 12, 2015 09:29 PM
