running with no vacum advance?
Old Jan 24, 2010 | 12:32 AM
L0tuS's Avatar
i want to switch out my old stock vacum advance distributor with a mallory dual point that does not have vacum advance. will it run the same with out the vacum advance or what is needed. its a carbed sb
Old Jan 24, 2010 | 12:38 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: running with no vacum advance?
It will run. The vacuum advances the timing when accelerating.....a LOT of people run without one. I have no vacuum advance on my carbed 327 chevy that's in my mustang (yes ford).......runs great,
you just have to set the timing advance a bit different if you want. have the centrifical weights open the timing a bit faster.
Old Jan 24, 2010 | 12:39 AM
Engine: L98 494hp
and you could go pull and plug the vacuum line to the distributor you have in there now, and drive it to see that it doesn't affect it that much.
Old Jan 24, 2010 | 05:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Wrong
Vacuum advance works by using a engine vacuum to advance the timing at low to mid engine load for fuel economy and better drivibilty. No or little engine vac when accelerating at WOT, so the timing advance returns to the base advance timing in addition to the mechanical advance.
Read this
http://www.stoveboltengineco.com/howto/vac.htm
Old Jan 24, 2010 | 12:45 PM
L0tuS's Avatar
Originally Posted by vetteoz
thanks it looks like ill be buy a new distributor
jhawkeye
May 25, 2022 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
armybyrd
Aug 10, 2015 09:23 PM
marcusaw
Aug 10, 2015 08:13 AM
