Massive Loss of Oil, any suggestions on where to look first
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
I am losing oil like crazy, 3 months ago was my last oil change i changed it a few days ago and only bout 2 1/2 quarts came out, where could i be losing oil, there is no puddles in my garage and no smoke out the pipes
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Massive Loss of Oil, any suggestions on where to look first
did you check your coolant? if its still green, then i'd say check the plugs to see if your'e burning it off.
Car: 1991 Camaro RS
Axle/Gears: Factory
my radiator is slowly going up, i just bought a new one today, are you saying that could be part of the problem?
Car: 87 Camaro
No, hes saying check your coolant to see if there are any indications of oil in the antifreeze. If not, and there isn't oil anywhere externally, then its losing oil internally. Either through bad rings or bad valve seals, or a few other things. Pull your plugs and check to see if they look like they've been burning oil.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
How many miles in that 3 mos? If it was more than 1500 or so, it's not that bad. A quart every 1K or so it considered "normal" by most manufacturers.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
