wont start after overnight
Old Jan 26, 2010 | 10:53 PM
Mateo1606's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI (L03)
Transmission: THM-700R4
Axle/Gears: GM 10 Bolt
ok next question? my car starts right away when its warm out and after I started it up in the mornign, it will start first try right away all day. But if I let if sit overnight and its a cold night, When i go to start it in the morning it will start up and die that second if i try again it keeps doing the same thing UNLESS i gently press the gas as i start it. if i do that BOOM she starts right up just as normal! Most of the time it does not do this it takes a very cold night to make it happen. Anyone have any ideas? I am thinking it may be the fuel pressure reg is just getting old cuz if i set my foot on the gas as i start her boom she starts.
thanx
Old Jan 28, 2010 | 03:55 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: wont start after overnight
It would be easier to diagnose this problem if you would tell us what kind of car you have, engine type, trans, etc.
Old Jan 28, 2010 | 07:05 PM
Mateo1606's Avatar
HAhaha yeah great point sorry lol its a 90 formula with a 305 TBI and a 700R4 Tranny
Old Jan 28, 2010 | 07:26 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I'd check the IAC. I've had mine stick shut before from carbon/sludge buildup. Pull it and clean it up with some WD-40/electronics cleaner/brake clean/whatever you have around.
Old Jan 28, 2010 | 07:32 PM
Mateo1606's Avatar
it should be fine i will try cleaning it tomarrow but it is i think about 5 months old i replaced it not long ago
Old Jan 29, 2010 | 08:03 PM
Mateo1606's Avatar
last night pulled the IAC at like 3am lol and cleaned it it was a lil dirty but not to bad put it back on and this morning it was very very cold and did the same thing still started then stoped first try second try started with out me pushing the gas tho. any other ideas on what to check maybe? thanx
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
