fuel pump relay question.
Old Jan 27, 2010 | 08:15 PM
firstcamaro89's Avatar
Car: '89 camaro RS
Engine: 305 TBI
Transmission: 700 R4
i just replaced my fuel pump relay and my car ran fine for about 2 weeks. Then it sat for about a week in the rain. now it hard starts again.The corners of the hood are curled up from the hood flying up on the freeway. water could have gone directly on the relay, could this make it stop working? or does another blown relay mean the pump is bad? THANKS FOR AANY HELP.
Old Jan 27, 2010 | 08:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pump relay question.
What lead you to believe it was the relay?
Old Jan 27, 2010 | 08:42 PM
Car: '89 camaro RS
Engine: 305 TBI
it was hard starting for a while, the relay got replaced and it worked. i checked the fuse and it's okay. i'm pretty sure it's the relay because it's acting exactly the same. i think the relay could have gotten water in it.
Old Jan 27, 2010 | 09:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Roll the window down, turn on the key and listen for the pump running. If the pump runs the relay is ok. Something else probably causing the trouble. Maybe water/moisture under the dist. cap or something.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
