Need help! New distributor and EGR harness
Old Jan 28, 2010 | 11:32 PM
energycontacts's Avatar
I just installed a new distributor on my 5.7L. In the process of removing the old distributor, i broke on of the weak tubes on the EGR Harness. I didnt know what i broke at first, i figured to try and run the new distributor anyways. I did the top center...lined up the mark on the crankshaft pulley to the "0" on the indicator as well as putting the rotor to face between the 1 and 8 on the cap. I could not get it to fire up. My question is does the broken tube on the EGR harness have anything to do with the car not firing? I need some help, if it is not the EGR, i might not have gotten the rotor at the right spot. Any help would be appreciated.
Old Jan 29, 2010 | 06:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help! New distributor and EGR harness
Originally Posted by energycontacts
I did the top center...lined up the mark on the crankshaft pulley to the "0" on the indicator as well as putting the rotor to face between the 1 and 8 on the cap. .
Was it on the compression stroke #1 TDC? .
# 1 Piston comes to the top twice when pointer showing TDC
Dist could be 180 degrees out
Hotrodboba400
Dec 10, 2019 07:07 PM
Jlanz55
Sep 9, 2015 09:09 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
