CODE 34?
Old Feb 1, 2010 | 10:05 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
CODE 34?
Hi umm i scanned my car for codes and i got a code 34..but i dont know where to look for the loose connection or what exactly im looking for..if anybody can help me out that would be great thanks.
Old Feb 2, 2010 | 02:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Draw A MAP
The MAP sensor is defective or there is a problem with the wiring going to it.
The MAP sensor can usually be found on the firewall, near the top, 2/3rds to the right.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 2, 2010 | 05:52 PM
Engine: 350 tpi
Re: Draw A MAP
and i can i replace it?? cause i know its alot of wires but i dont know exactly which connection it is...if i dont got a speed sensor can that cause the code? i read somewhere that the speed sensor caused the code 34..
Old Feb 3, 2010 | 02:34 PM
NINÅ's Avatar
Transmission: 765R4
Draw A MAP
If you’re seeing “a lot of wires” you might not be looking at it.
The MAP sensor usually is connected VIA a 3 wire plug, plus the hose.
Happy Racing!
Old Feb 3, 2010 | 02:51 PM
Engine: 350 tpi
Re: Draw A MAP
Ok then will hav to check when the rain stops thanks
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
