87 balancer
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
87 balancer
I have a 87 iroc with the tpi and it has the small flywheel with the weight on it but my brother replaced the balancer a long while back and it is the netural type with no cut out like the 400 383 type balancers. Is the 87 1 peice rear main supposed to have the weighted flywheel but netural harmonic balancer? I know the flywheel is correct but I dont know if he put the wrong balancer on it. Any ideas anyone????
Transmission: 4L80E/4L80E
For one-piece rear main seal cranks, the external weight that was built into the 2-piece rear main seal cranks external to the rear main seal had to be moved to the flexplate/flywheel. As Aperion noted, that didn't affect the damper, which is neutrally balanced still.
Car: 87 iroc z
Engine: 358 tpi
Re: 87 balancer
Ahh that explains the reson for the weighted flexplate. I always wondered about that but now I know. Thanks!!!!
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
