fuel tank sump or just bulkhead fitting
Old Feb 6, 2010 | 11:25 AM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Hello, I know that this has been discussed a few times but I had some questions. I need to redo my fuel system and had some questions.
I know a lot of people add sumps to the stock tank, but looking at the shape and mounting of a third gen tank I almost wonder why. With the stock tank having the rear downhill I wonder why a person can not just weld a fitting to the rear of the tank, or maybe just drill a hole and add a fuel cell bulkhead. This may seem like a half *** way to do it, but with the thirdgen tank the fuel is always going to want to sit in the rear anyway. On some cars the tank is shaped different to where this would not work.
So has anyone tried it. Is there some info I am missing?
Old Feb 6, 2010 | 01:55 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: fuel tank sump or just bulkhead fitting
I have thought of doing this before and would like to see if it works.
Old Feb 6, 2010 | 02:21 PM
GXR11's Avatar
Car: 91 C1500, 84 Camaro, 87 monteSS
Engine: 4.3L,Gen1 350. 391ci & 383 LS1
Transmission: t-5,man vavle body 700r4, no trans
Axle/Gears: 3:73, 3:42, 4:10
im also interested in this one. im getting ready to redo the fuel system in my 84 and looked into tanks, cells, ect. the only cell that was a bolt in was from fuel safe....24 gal. for $2500. not what i was trying to spend on the tank.
ive read were some people were using tanks from 4th gen.'s. didn't fit perfectly but were able to make it work. and there are some less expensive 4th gen. tanks/cells with sumps welded in.
so keep us posted on what ya do and how it works...
Old Feb 6, 2010 | 05:45 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
i have a fuel cell bulk head with a 45 degree -8 and -8 line to the filter then to the pump and to the regulator then -6 from the reg to the bowls.
Old Feb 7, 2010 | 08:17 AM
bart91406's Avatar
Car: 91 rs
Transmission: th350
I think the bulkhead makes sense,the tank is naturally sumped by the way it is mounted in the car, so I am going to try and drill a hole, then place a fuel cell bulkhead in it with a jamnut on the inside of the tank, and a nylon seal and jamnut on the outside, I will let you guys know if it works.
Old Apr 4, 2010 | 06:21 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am wondering if you have done this yet. Did it work and not leak? I really want to do this as well.
Old May 9, 2010 | 10:35 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
hello?
Old Oct 8, 2010 | 08:24 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
little late i had a steel #8 welded to the tank no leaks no problems just try and get a bigger thread size as possible (more to weld on) i used a 7/8 size thread
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
