Fuel pump Help!
Old Feb 6, 2010 | 08:56 PM
mesterious's Avatar
Fuel pump Help!
Ok i have a 406 SBC that should put out at an area around 550 HP and i need to know what kind of fuel pump(preferrably mechanical) I should get. I dont know much about fuel pumps so maybe you all can even spec me out one or just tell me what i need to look for.
Old Feb 6, 2010 | 08:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel pump Help!
What induction system?
Old Feb 6, 2010 | 09:05 PM
mesterious's Avatar
Re: Fuel pump Help!
Holley 4150 850CFM, Edlebrock Super Victor, and AFR 210 Cylinder Heads
Old Feb 6, 2010 | 09:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Fuel pump Help!
Carter M6900, or a Carter M4891 with an external bypass regulator.
Old Feb 6, 2010 | 11:42 PM
mesterious's Avatar
Re: Fuel pump Help!
Wow thanks again for the 2nd time haha.. last question though carbed engines dont need alot of Fuel PSI do they?
Old Feb 6, 2010 | 11:48 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Fuel pump Help!
No. But they need volume, especially a higher horse motor.
Mark.
Old Feb 7, 2010 | 09:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Fuel pump Help!
Too much fuel pressure on a carb is a bad thing, the floats can't control the fuel level in the bowls and they flood. Around 6 PSI is about normal, much more than that and problems start.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
