starts but not well
Old Feb 8, 2010 | 06:03 PM
mikeyg785's Avatar
Car: 1986 camaro iroc z28
Engine: 305 tpi
Axle/Gears: stock 2.23
starts but not well
so recently my 86 camaro hasnt been starting up to well but it does start. when i turn the key like i normally would it starts up but then cuts out right away. if i turn it for longer then it should be turned it starts but you can tell theres something wicked wrong because it makes a weird noise and you can tell its really close to stalling but doesnt. once its running its runs fine. it also seems like it loses a little power like you have to press the gas more, but its very rarely that that happens. so i was jw if anyone knew what the problem might be. thanks
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
