my buddies 350, will it run
Old Feb 10, 2010 | 06:12 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
so one of my friends put his 350 back tgether, it was a compltete long block when he got it, he took the heads, timing chain, pulled the came out. Now he put the cam back in, also the timing chain na nd didnt mark anything and doesnt wana pull it apart. after reinstalling that he now rotated the crank so it was at tdc. Will it run or no???
Old Feb 10, 2010 | 06:18 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: my buddies 350, will it run
didnt mark anything?? did he at least line up the timing chain gears??
Old Feb 10, 2010 | 06:39 PM
budget350's Avatar
Car: 87 iroc, 91 rs
nope, didnt line up anything, not even the timing chain gears.
Old Feb 10, 2010 | 10:32 PM
Noskill's Avatar
Car: 92 rs 25th anv.
Engine: 5.0 305 TBI
lol if he didnt at least line up timming gears i would be willing to bet it is atleast a 180 deg out im betting on it will not run need to pull back apart and dial in cam and aline timmg gears
Old Feb 11, 2010 | 07:09 AM
budget350's Avatar
Car: 87 iroc, 91 rs
so even if he put the dist. 180 outt still wouldnt run???
Old Feb 11, 2010 | 07:34 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if the cam and crank are not lined up, you're looking at destroying that motor. do not start the engine until you pull the timing cover and line the cam and crank gears. does not matter where the distributor is, you will break stuff.
Old Feb 11, 2010 | 07:48 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Better spend an hour or so taking the front cover off now because you will be doing it later with some bent valves at the very least. My .
Mark.
Old Feb 11, 2010 | 08:45 AM
budget350's Avatar
Car: 87 iroc, 91 rs
i wish he would of called me before he did this. Im goin to call him and let him now wats up. Thanks guys
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
gwade12
Aug 8, 2015 08:17 AM
3rdgenparts
Aug 6, 2015 09:03 AM
