Fuel Pressure Transducer for EBL???
Old Feb 10, 2010 | 10:58 PM
Killerzracing71's Avatar
What can work? Any?
Where can I find one tad bit cheaper then $90, or is that what im going to pay?
Old Feb 12, 2010 | 01:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"EBL"?
Old Feb 12, 2010 | 10:40 AM
Re: Fuel Pressure Transducer for EBL???
Originally Posted by five7kid
"EBL"?
Dynamic EFI Embedded Lockers Flash system.
I know you know what that is.............
http://www.dynamicefi.com/
Old Feb 13, 2010 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can use any one of three different Autometer transducers. Or with the latest WUD can use any sensor/transducer with a linear output.
Here are the three Autometer units:
Product #: 2245, 0 - 15psi
Product #: 2239, 0 - 30 PSI
Product #: 2246, 0 - 100 PSI
All have a 1/8" NPT Male Thread. Unfortunately they are pricey. But for monitoring fuel and oil pressure are the only way to go.
Note that there are manufactures that make transducers such as Honeywell, SSI Technologies, and Kavlico. An important item to check is that the transducer has a built in amplifier circuit. Which produces a linear voltage output. Not a bridge type output which needs an external amp or a current type output.
It will be similar to this: 0.5 – 4.5 Volt output (with 5V input)
RBob.
Old Feb 13, 2010 | 11:52 AM
Yeah Id like to get one, so I can make sure I dont have a pressure drop and log it.
Well see what happens.
Old Mar 7, 2012 | 07:38 PM
Mastiff's Avatar
Resurrecting old thread. I got one of these transducers and now I'm wondering how to wire it up cleanly. It's obviously intended as a replacement item and would normally have a custom mating connector. Any ideas?
Old Mar 7, 2012 | 09:13 PM
Mastiff's Avatar
Here's the real way: http://www.summitracing.com/parts/ATM-5227/?rtype=10
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
