wont idle pass 2grand in gear
Old Feb 11, 2010 | 09:00 PM
dj_phoenix's Avatar
Car: 1986 firebird
86 firebird 305 carburated, im having two problems right now. one started after the other so not sure if there related. 1st- after driving car for a good 20 minutes or so, when i stop and turn off the car it will not turn back on for atleast an hour. i turn the nkey to crank, but nothing happens. all gauges and lights turn on but there is no crank at all. had the ign coil and distributor module checked, both were tested 3 times and passed all 3 times. anybody ever ran into this problem before??
2nd-this started a few days after the first problem, i can rev the engine past 2000 rpm while it is in park, but once i put it in drive it wont go past 1800 rpm. it will start actin like its starving for gas and throw black smoke from the exhaust. carburetor is only 2 months old. anybody can help me out id gladly appreciate it.
Old Feb 12, 2010 | 01:13 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: wont idle pass 2grand in gear
hmm, don't really have an answer for you on your first question. But black smoke generally indicates its running very rich. Is the carb a stock reman or aftermarket?
Old Feb 12, 2010 | 07:26 AM
dj_phoenix's Avatar
Car: 1986 firebird
its a rebuilt quadrajet
Old Feb 12, 2010 | 08:02 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
then it must be an electronic quadrajet?
Old Feb 22, 2010 | 05:07 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
When you put the new carb on, did you have it tuned? More than likely your new carb isn't tuned to your motor so if you are running rich it could cause some of your problems. As for why it won't go past 1800, I'm not sure, I've had some similar problems on mine that come and go periodically.
Old Feb 22, 2010 | 11:05 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
sounds like your first problem could possibly be the ignition switch, the one thats located bolted to the steering column under the dash, I had that problem once on my old 91 bird, though it was the starter acting up again til I replaced the starter and still same thing, it could however be your starter because the reason I thought it was my starter was because that 91 bird went through 3 starters the first 3 years I had it, each one when dying did that same thing, no crank at all, sometimes no power to anything at all like the battery was disconected, bought a aftermarket high torquer and never had starter probs again.
Old Feb 23, 2010 | 06:37 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
to OP, do you have headers? have you tried remote starting your car?
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
86IROC112
Aug 21, 2015 07:20 PM
jbd1969
Aug 17, 2015 07:06 PM
