smog pump
Old Feb 13, 2010 | 11:14 AM
Noskill's Avatar
Car: 92 rs 25th anv.
Engine: 5.0 305 TBI
smog pump
Hi i have a 92 rs 305.. if i reroute belt to miss smog pump will i have to remove it rite away?.. the pully is making some noise.. thanks for the help.
Old Feb 14, 2010 | 10:52 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: smog pump
You don't have to remove it but you do need a belt that is a bit longer, here is what I used goodyear belt part #4060967, hope this helps.
Old Feb 14, 2010 | 11:48 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: smog pump
If your bypassing the smog pump wouldn't you need a shorter belt? last 3 number of part# tells me it's a 96.75" long belt.
Old Feb 15, 2010 | 03:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Belt Or Suspenders ?
92RS702 is correct.
You need a longer belt do to the new routing.
You should remove the pump.
Less weight, cleaner engine compartment, more room.
You might have to at least remove the pulley.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 16, 2010 | 11:40 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: Belt Or Suspenders ?
Yeah I'm thinking of removing my smog pump as well since my car isn't due for emissions for another 2 years. Does anybody notice any gains after bypassing it?
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
