355 build witch heads are better
Old Feb 15, 2010 | 04:55 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
I am trying to choose witch heads are better for my fresh 355 short block.It has speed pro flat top 4 valve relief pistons.set one is Summit Racing SUM-151124 - Summit Racing® Vortec Cylinder Heads and set 2 is White Performance PRO COMP 210cc 2.02/1.60.I am running a .447 lift cam sae 291int. and exh. .050 223 int. and exh.
Old Feb 15, 2010 | 04:58 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Re: 355 build witch heads are better
Get the summits. You don't want anything made in china.
Old Feb 15, 2010 | 07:20 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I second the Summits over the Pro Comps!
Old Feb 16, 2010 | 07:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
3rd.
Reddeath210
Oct 6, 2015 08:20 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
theurge
Aug 21, 2015 12:46 PM
