383 Reliabilty?
Old Feb 17, 2010 | 10:39 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
383 Reliabilty?
I have a 383 that was built to very tight specifications and has around 900 miles on it. Hasnt broken in yet (has chromoley rings). How long do you think the engine will last if driven relatively easy?
Old Feb 17, 2010 | 11:17 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: 383 Reliabilty?
that question is almost impossible to answer....should go 100K if taken well car of.
Old Feb 17, 2010 | 11:28 PM
Stephen's Avatar
Car: 87 GTA
Re: 383 Reliabilty?
My 350 is at 210,000 miles are still runs as good as day 1...LITERALLY! I've lost 1mpg, from the factory rating & she starts withing 1 revolution of the crankshaft.
That being said.....
Your 383 is no different. Treat it right, keep it up good & it could last you 200,000+ miles too. Chances are, your engine was built with closer attention to it assembly specs than my factory, mass-produced 350 was.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
