piston questions
Old Feb 17, 2010 | 11:46 PM
luke89's Avatar
Car: 96 jeep cherokee, 89 camaro
Engine: 355
Transmission: t5
Axle/Gears: eaton locker/3:73 gears
piston questions
hi im rebuilding a chevy 350 30 over and wanna know what are cheap goood pistons. i was lookin at these two.
http://www.summitracing.com/parts/TRW-8KH345NCP30/
what does it mean when it says +5.00cc? and what would my compression be with these?
http://www.summitracing.com/parts/SUM-17350-30/
these ones are +6.00cc? and what about compression with these?
another question i got is are the eagle cranks good. i was gunna buy one for 170 instead of getting my old one redone for the same price.
Old Feb 18, 2010 | 01:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: piston questions
The +5.00cc and +6.00 cc are the volumes of the valve reliefs. You have factor that in to the compression ratio calculation.
Your compression ratio will vary with the chamber size on the heads, what head gasket you use, and the deck height of the block.
Old Feb 18, 2010 | 06:48 AM
luke89's Avatar
Engine: 355
Transmission: t5
well what would a rough estimate be with 76 cc heads and stanard deck height.
Old Feb 18, 2010 | 09:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
About 9:1
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
