heater issues, please help!!!
Old Feb 18, 2010 | 06:14 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
I'm having some issues with heater controls on a 1986 Berlinetta camaro, the controls don't operate at all. I've checked all the fuses, wiring, and components. I haven't been able to track down the problem. The blower motor does work in all speeds if you manually apply power to the correct corresponding wires. about the only thing that does work is the wiper controls and the illumination of the complete unit. The LED's for the speed selection, and or vent selections don't light up either. I have tried another control unit in which I purchased from Ebay, with the same results. The car has been sitting for a long time, with only 24,000 original documented miles. I have already removed the speedo cluster and had that serviced because it was reading erractically (problem is solved with the cluster). I'm really trying to get this operating correctly, but I believe that the controls themselves maybe bad. I have heard that they were known to go bad frequently. Any advice or repair tips would be greatly appreciated
Old Feb 18, 2010 | 06:28 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: heater issues, please help!!!
I'm guessing the hvac is stuck on defrost?
You need to get the vacuum to the control. Mine was disconnected near the brake booster.
Old Feb 18, 2010 | 06:45 PM
actually mine doesn't blow at all, there is abosulely no heater functions whatsoever
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
