Gas gauge is stuck
Old Feb 20, 2010 | 02:50 AM
wabbitslayer's Avatar
Car: 87 Trans Am
Axle/Gears: 3.23 posi
Gas gauge is stuck
my gas gauge is stuck at 1/2 a tank, Im not sure on how to go about fixing it.
Old Feb 20, 2010 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gas gauge is stuck
The gauge or sender is shot. The gauge can be replaced from the front, without cluster removal. Perhaps a half an hour job--at least on a Camaro. The sender is a different story. A search might provide diagnostics for both.
JamesC
Old Feb 20, 2010 | 09:45 AM
s10devil's Avatar
Car: 84 z-28/2002 S10
Transmission: BW T-5
Years back I had a Z34 Lumina that did the same thing. Turns out a piece of that plastic liner in the tank broke off and got caught under the float. Don't know if that's it, but a full tank of gas and a bumpy ride might move it if it is. Figured I'd chime in, it sounded like a simpler place to start.
Old Feb 21, 2010 | 01:15 AM
Car: 87 Trans Am
ok cool i will try to find a working gas gauge and see if its the problem.
Old Feb 21, 2010 | 03:28 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ive personally had NO luck with factory gauges, my original one would either read full, half, or empty, so i replaced it and it worked great for about a day, now its either maxed out beyond full, or empty, or it says ive got 3/4 when i hit a bump juuuuusst right lol
Old Feb 21, 2010 | 01:24 PM
Vader's Avatar
Read the resistance of the sender. That should help identify whether it's the sender or dash guage.
Old May 1, 2010 | 09:04 AM
timonator's Avatar
I have the same problem with my daughter's Z. How do I read the resistance? I have a meter,just don't relly know how to use it.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
BurlyChev
Aug 16, 2015 09:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
