305 to 350 swap question!?!
Car: 1986 Camaro I-Roc
doin a 305 to 350 swap in my 86 iroc. I realize most everything is the same seeing as they are both small blocks, but i have a question about the torque converter? Am i going to have to change it? I dont have any specs on them. They both are stock converters as far as I know. Would i benefit from using one than the other...the 305 or the 350 TCC. It's a 700r4 trans. Also, other than the TCC, is there anything I might run into that would give me a challenge compatibility wise?
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 305 to 350 swap question!?!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 231 / 383
the MAF is the same.. except as I mentioned in the tuning..the knock OK different
My bad for not mentioning. It;s a carbureted setup. My 350 has a slightly mild cam in it. An edelbrock performer plus cam. This should be ok to use with the stock TCC, right?
Car: 82 Z28
Transmission: T400
