Sensor help!
Old Feb 21, 2010 | 07:33 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
Sensor help!
So I'm rebuilding the 305 in my 87 IROC and I'm a dumb*** I forgot to mark a sensor and now I can't remember nor figure out where the hell it goes. I'll post a pick of the sensor later tonight, but it has the same male end as the knock sensor on the passengers side, the sensor is on the passengers side. It comes off the section of the wireharness that has my throttle possition sensor and other throttlebody and intake sensors on it, all I know is that it's near mt knock sensor and starter, but I can't figure out where. Any help is much appreciated!!
Old Feb 21, 2010 | 07:40 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Sensor help!
Probably the secondary fan switch, goes in the passenger side head, right behind the exhaust port for cylinder 6.
Old Feb 21, 2010 | 07:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Sensor help!
Correct
Old Feb 21, 2010 | 09:27 PM
Car: 1987 IROC-Z
Re: Sensor help!
I thought that's where the second CHT(cylinder head temperature) sensor went.... But I guess I'm wrong.
Old Feb 22, 2010 | 09:35 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Sensor help!
There has only been one engine temperature sensor- gauge only (in driver side cylinder head.)
The coolant Temperature sensor is solely for the ECM because it's more accurate and representative of cylinder temperature - located front of intake manifold.
The passenger side cylinder head temperature sensor as has been said is a non computer controlled Heavy Duty Coolant fan with a fixed on temperature setting.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
