oil smoke
Old Feb 23, 2010 | 08:04 PM
bcmag's Avatar
oil smoke
my 87 iroc has typical small block oil on statup after hot soak and when snapping throttle.anyone have luck w/ umbrella seals solving this.heads are supposedly older iron double hump heads.
Old Feb 23, 2010 | 08:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil smoke
Umbrella seals aren't all that great, positive seals are much better.
Old Feb 24, 2010 | 05:57 PM
bcmag's Avatar
Re: oil smoke
yeah i know but usually they require machine work.i dont know if ill stick w/ these heads,just bought car and am still sorting it out but the smoke is very embarassing. thanks for your reply!
Old Feb 26, 2010 | 10:02 PM
BadHabit's Avatar
Car: 1989 TPI Formula, 1984 MCSS
Re: oil smoke
Umbrella's are a short term fix, but I feel your pain on the smoke issue.
New or fully rebuilt heads might be your best bet when you compare labor spent versus results gotten.
It really depends on your plans for the car and engine.
Old Feb 26, 2010 | 10:54 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: oil smoke
i herd umbrella seals are used with larger than stock springs and positive seals are better with double springs
Old Feb 27, 2010 | 12:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: oil smoke
Positive seals are better with any kind of spring.
Old Feb 28, 2010 | 09:41 AM
bcmag's Avatar
Re: oil smoke
do you think u mbrella seals will fit inside stock springs?do you know of any positive types that dont require machining?
Old Feb 28, 2010 | 11:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: oil smoke
I'd be surprised if your heads weren't already machined.
Old Feb 28, 2010 | 01:11 PM
bcmag's Avatar
Re: oil smoke
okay ill get a set just in case,however if not do you think umbrellas will fit in stock springs?
Old Feb 28, 2010 | 01:24 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: oil smoke
When I did my 87 the intakes had positive seals on them from the factory, the exhaust had o-ring seals. I put replacement positive seals on the intakes, and unbrella on the exhaust. The exhaust wasn't machined for positives.
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
Stryker412
Sep 20, 2015 06:59 PM
Accerrito22
Sep 5, 2015 09:34 PM
