big problem lots of help needed
Old Feb 25, 2010 | 10:25 PM
uncapj's Avatar
Car: 1987 camaro rs limited
Engine: 2.8 ltr multiport fuel injected
Transmission: th700r
Axle/Gears: 3.43
ok im back and this web site has been a huge help getting my project on the road but now that its running ive got another issue to deal with
when i start the car it will start right up but will go up to 30 to 3500 in park and neutral and when i put it in park it will go down to 1500 in drive or reverse or any other gear and runs ruff can anyone help me please is it a vacume leak and is it small or big and what can it be and also can it be a timing issue i need this fixed befor i can smog my car sadly i live in california the no muscle car mod state
Old Feb 25, 2010 | 11:36 PM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
Re: big problem lots of help needed
Ok, I probably know about as much as you do about cars right now because im kinda new, but no harm putting in my 2 cents right? Yes I do think your timing could be doing it, but also, what is your oil pressure like? My car is sort of having the same type of issues, and im pretty sure my timing has something to do with it. But what do you experts think? Timing isnt too hard to check, if you have the manual or if not the guys at autozone could help you with figuring out how to check it. you can listen for vacuum leaks, and also try looking up a vacuum diagram, i dont know if your car still has it, but there should be a sticker under the hood right by the front bumper that has a small diagram you can look at. mine is kind of faded out, but it helped me find a few lines that were either hooked up wrong or not hooked up at all. Trust me i know how you feel I live in california too, and smogging sucks!
Old Feb 27, 2010 | 12:27 AM
suzukiz400's Avatar
check the vacuum modulator on your trans. that might be leaking causing your idle problem
jhawkeye
May 25, 2022 06:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
