computer compatible?
Old Feb 27, 2010 | 12:05 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Is the cam in my car computer controlled? if i build a engine do i need to buy a computer compatible cam?
Old Feb 27, 2010 | 12:36 AM
suzukiz400's Avatar
Re: computer compatible?
depends if you would want to reprogram your prom, if you did so you would be able to get away with a larger cam, but if you left the computer the way it is now you cant go much bigger with out running into problems, i put a little bit bigger cam in my car witch was tpi and it never seemed to run quite right
Old Feb 27, 2010 | 12:59 AM
Engine: 350 for now
Transmission: wc t5
I am going to reprogram the prom. I was just searching some threads and people are saying that a tpi is computer controlled and needs a computer compatible camshaft. I was just wondering if thats true or can I put any roller cam i want in it computer compatible or not as long as i reprogram the prom?
Old Feb 27, 2010 | 05:09 PM
suzukiz400's Avatar
you might have to talk to some one who can reprogram proms, but as far as i know you can put any size you want in as long as you reprogram it
tmellott89
Oct 14, 2015 02:06 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Damon
Sep 26, 2015 04:29 PM
