NEED STOCK CAM SPECS
Old Feb 27, 2010 | 01:52 PM
SR85KnightRyda's Avatar
i need the stock cam specs for my 85 firebird has a 305 engine with a 5 speed transmission.....no trans am just the basic firebird.....my buddy is in need of a working 700r4 too if any one can get at me with that....
Old Feb 28, 2010 | 07:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: NEED STOCK CAM SPECS
TPI? 4bbl std, or 4bbl HO? All used different cams.
Old Apr 11, 2010 | 11:25 PM
4brrl standard.....
Old Apr 12, 2010 | 12:52 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The LG4 cam specs are impossibly tiny. 178/194 duration at .050", .350/.385" lift, IDK the LSA. Why not get something slightly better? You can do a little better without hurting anything. Wouldn't even need any tuning or any parts changes, beyond new lifters, a new timing chain, and a cam change gasket set.
Old May 12, 2010 | 11:05 PM
yea thats wat im tryin to do...get a bigger cam installed without changin my valvesprings.....i have roller tip rockers new lifters and 7.900" pushrods w/ guides.....jus need a cam
Old May 12, 2010 | 11:32 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
springs are a wear item. All you need to change them is a $20 tool you can get at your local NAPA. springs are $26, plus a small s&h charge, and you can do the valve seals while you're at it for another $16 or less.
For springs, try www.competitionproducts.com, part # 98111.
for a cam, I'd use a Summit K-1101, with or without new springs.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
