Camshaft and Timing Question
Old Mar 1, 2010 | 10:03 AM
gunner1204's Avatar
Car: 1987 Camaro Z28
Engine: 355c.i. Carb.
Transmission: TH350
I have a 355c.i. with MSD 6al ignition, I want to upgrade my cam and wanted to hear if some of you guys have done this. Also if you have what problems did you run into and include what kind of cam you bought with lift and duration. In addition to that what was your timing set at?
Old Mar 1, 2010 | 10:18 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Camshaft and Timing Question
my cam is the comp extreme fuel xfi280HR. LOVE the cam, I would go with an extreme fuel series by comp, they make many different sizes and are designed for fuel injection/tuned port style setups. I have the cam timing set a 0 deg adv/ret (reccomended by comp) and the ignition timing set at factory six degrees with the extra timing programmed into the com puter itself. my cam sizes lift and dur. should be in my sig.
Old Mar 1, 2010 | 10:25 AM
gunner1204's Avatar
Transmission: TH350
Im running a carb. intake and i have been researching the lunati voo-doo cams. any thoughts on those? also i know I'm going with mechanical flat tappet.
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
