coil arcing
Old Mar 4, 2010 | 02:24 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
coil arcing
The external coil on my 2.8L is arcing from the plug tower to the coil body. Does this indicate a bad coil or bad cap (current taking the path of least resistance i.e. not the cap)?
Old Mar 4, 2010 | 05:37 AM
Damon's Avatar
Re: coil arcing
Definitely shouldsn't be doing that. If you're on a very tight buget you could start by just changing the coil wire- it might have a breech in it somewhere near the tower allowing the spark to escape. If that doesn't work change the coil (body might have a small crack in it). Neither part is very expensive.
However, usually when you find sparks getting to the outside world with older parts it's usuall an indication that many of the parts are past their prime- wires, plugs, cap and rotor, in which case it's best to replace all of them as part of a complete tune-up.
Old Mar 4, 2010 | 05:28 PM
RSFreak's Avatar
Re: coil arcing
Almost every part of the ignition system is new or somewhat new. Cap, rotor, wires, plugs, and distributor have all been replaced recently. The coil is an MSD Blaster II which is a few years old. I'm also running an MSD 6AL. Guess I'll start with the coil and cap and see if that fixes it.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
