What is this????
Car: 92 RS camaro
What is this????
Ok so in the process of changing the ful pump this broke off from 1 of the lines. I went to all the local parts store and not only could they not get it, but they couldn't even tell me what it was. I figure it has something to do with pressure because it blocks the line and is springy on the back side. There is supposed to be was looks like a tub on the other side(thats the part that broke)
The reason i ask this is i'm getting no fuel through my lines and when i got under there i noticed this broken. If my fuel pump was running would this stop me from getting fuel in my lines? if not 2nd question
I hear my fuel pump running. Is it possible to accidently wire it backwards and it not work? I can hear it running.
Car: 1989 Camaro RS
Engine: 305 TBI
Re: What is this????
I remembered your post when I stumbled across this
https://www.thirdgen.org/forums/carb...tify-part.html
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Have you tried at your local Chevy dealer?? That's where I got mine from!!
