Sparks Coming from engine block when key turned
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
Just put my 350 back together after a saga with vortec heads. Went to start for first time. It ran, but when I turn the key, there is a large spark originating by the fuel pump and motor mount on the passengers side. Why is this happening?
Also, backfiring through the carb (Edelbrock 650cfm)
Car: 84 Z28 and a 95 Z28
Engine: Built 350 sixty over
Transmission: W/C T-5
Axle/Gears: 4:56s auburn posi, mosers, girdle
Re: Sparks Coming from engine block when key turned
You obviously have a short to ground. Check all wires and make sure you dont have a hot wire grounding out on the block, may have a plug wire with the insulation worn through arcing on the block as well. Hard to tell the from description
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your spark is probably just a bad ground. Make sure the block is grounded to the frame with a good heavy ground strap and the battery is grounded to the block.
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Also try advancing your timing to stop carb backfiring.
