msd???
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: msd???
didnt you post this in the power adder section??
I would just go back and re-check all the wiring, you probably messed with the wrong wire.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: msd???
the only grounds i messed with was the one the attaches to the wire from the msd box and then the one that comes of the distributor cap... i grounded that out on the motor... should i have done it on the body instead?
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
