new motor build question
Old Mar 10, 2010 | 09:05 PM
Andy316's Avatar
Its going to be a 383. With the milled vortecs I have, it will put the SC right around 11:1. But my DC with the cam will be around 7.3:1. My quench will be .040-.045". My question is, will the motor be able to run on pump gas with that much comp. and iron heads?
Old Mar 10, 2010 | 09:10 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: new motor build question
That DCR is definitely low enough for pump fuel. It shouldn't be a problem until your DCR goes above 8.5:1, and I think there are some motors I've seen around 9.5:1 still on pump gas.
Old Mar 10, 2010 | 09:13 PM
Andy316's Avatar
So it doesnt matter if the heads are iron or alum. I just keep hearing the folk lore that high comp. and iron heads dont mix. I thought that with such a low DCR it wouldnt be bad. Im still learning all of this stuff so bear with me.
Im from the cincy area in ohio. Just noticed you are from ohio.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
