Is it me ? , or is it Felpro gaskets ??? pics inside .
Old Mar 9, 2010 | 11:27 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
well,long story short , head gasket blows , rebuild , post rebuild runs rich , cant figure out why so i go back and check for intake manifold leaks and i find that the gaskets had the two rear water ports blocked off " looks like they didnt cut them out , all it had was a little hole " also my EGR ports were not there , they hadnt been cut out , so i buy new Felpro gaskets "same ones basically " except this time all four water ports are cutout yet the EGR ports are still not cutout , anyone else experience this ? can i cut out the sections for the egr ? pictures below BTW sorry for posting pictures this big , i dont know how to attach them the other way .
Size:  12.5 KB New Gasket
Old gasket , new one also has EGR ports blocked off .
Old Mar 10, 2010 | 12:30 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
Re: Is it me ? , or is it Felpro gaskets ??? pics inside .
wierd,did you get the gaskets at the same store?
Old Mar 10, 2010 | 01:38 AM
Guest
Guest
Posts: n/a
There are some different gaskets available, maybe you were given the wrong ones. The MS 93317 appears to have the EGR port and a small hole at the rear coolant passage. That seems to be the part number for the 87-up heads and TBI. I am pretty sure the set for the TPI (that includes runner gaskets) uses the MS 90314-2 intake gaskets. Those have ports for both water front and rear and the EGR port.
Should not be an issue with drilling a hole for an EGR port, but I'd try to get the correct gaskets instead.
TBI?
Looking at your 2nd picture, all the EGR ports I know of are in the middle of the gasket. I dont know what those holes in the intake are for, but I think if you look at the head you'll find there are no holes there.
Old Mar 10, 2010 | 09:13 PM
the first pair of gaskets i got @ autozone , they came with head gaskets and a bunch of other little gaskets , the second pair i got from summit , it said it was for the 88' year model " and yes i made sure it was for the tbi . Here's my intake manifoldbtw. i checked for any EGR ports on my heads and there is one one each head between intake ports 4 and 6 , and 3 and 5 , exhaust gas flow through them
Old Mar 10, 2010 | 09:18 PM
and here's another pic. of the gasket that i got from autozone " its the one i used for the rebuild "
" <== Poor coolant flow "
" this was blocking coolant flow @ the rear ports , hopefully i didnt blow my head gaskets again.."
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
qz6lwp
Aug 20, 2015 08:10 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
