setting timing marks
Old Mar 11, 2010 | 05:42 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
is it ok to simply line up the timing sprocket marks to set the timing on my 355.will I have enough adjustment in the distrubutor?I think using a degree wheel and all that is a little above my current Know how.
Old Mar 11, 2010 | 05:47 PM
Twin_Turbo's Avatar
Re: setting timing marks
You mean cam to crank timing? Yes, dot dot is fine, either 12-12 or 12-7 (< TYPO!!!!!!!!!!), doesn't matter. The only diff between the 2 is stabbing the dizzy 180 apart.
Old Mar 11, 2010 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
12-6 would be a lot better than 12-7.
Personally, I always do 12-6. 12-12 is just too much of a guess.
Distributor timing is not affected by the cam timing since you're going to be adjust that, anyway.
Old Mar 11, 2010 | 06:38 PM
Twin_Turbo's Avatar
Obviously a typo no? Love the smart remarks here
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
