Installed polished Underdrive pulleys on new motor, need spacer for crank pulley???
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
So i bought a polsihed set of underdrive pulleys and finally got around to putting them on. They were made to fit a 90-99 SBC vortec 350/305 but i asked the owner if it would fit my motor and he said yes. Well i put my new belt on and relized while the engine is running that the crank sits farther back then the waterpump does so only 4 out of the 6 ribs on the belt is on the crank pulley. Im guess its because I have a long waterpump and not a short? Is there anyway to space the pulley out farther from the crank so it will line up with the waterpump or do I need to just buy a whole new pulley???
Id had an idea to go to a 4 ribbed belt instead of a 6 but im not sure if it would move back and forth on the other pulleys at high rpm. Any suggestions??
Navy8125
Aug 22, 2015 07:13 PM
kah992
Aug 19, 2015 02:55 PM
Street Lethal
Aug 12, 2015 11:33 AM
