Stock Valve Spring height
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
I talked to a comp cams tech guy and he told me that they do have valve springs to fit my heads without machining he just needs to know the valve spring height.
So my question is what is the factory valve spring height on a 350 TPI motor so that I can get the right springs ordered for my cam finally...I don't wanna hear oh you should machine the heads...that's not my question please just answer my question.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Stock Valve Spring height
stock is usually 1.8-1.9" installed. its best to measure for yourself. is the engine disassembled?
Car: '87 Iroc-Z
i have no way to do this. yes it's disassembled
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
