Routing new 1/2" fuel return line. How did you go about doing it?
Old Mar 18, 2010 | 08:20 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Well, I found out my return line back to my tank is well too restrictive for the fuel pump I am running. (Walbro 255lph) I have the Mallory 4309 regulator and a holley DP carb. The pressure would not drop below 10-11 psi so I am going to route a larger return line. What is the easiest, or the best solution in doing this? I'm more or less confused on what i have to do once I get the new line back to the tank???
Thanks for the input.
Old Mar 19, 2010 | 01:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The pump mounts to the return line on the pick-up. You either need to replace that line in the pick-up, or run another one.
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
Grant2k
Jul 10, 2018 04:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Kaweh
Aug 9, 2015 02:54 PM
