Gasket questions
Old Mar 21, 2010 | 04:04 PM
Camatruder's Avatar
Car: 88 Camaro V6
Gasket questions
Hi,
this car is giving me a lot of firsts, so i"ll may be asking a few stupid questions.
I'm currently rebuilding the engine after changing the timing chain and sprockets, the waterpump, setting valve lash,...
The installation guide of the new waterpump instructs to coat both sides of the gasket with sealer, but the Haynes manual doesnt. I cleaned all mating surfaces as thoroughly as possible, but will use a sealer anyway.
I have two different RTV's laying around : Loctite 587 and Loctite 5923. Both are blue and suitable up to 500 °F.
Which RTV should I use?
Can I use this RTV also for the threads of the bolts?
Should I use this RTV also on the timing cover gasket?
I bought 1-piece rubber gaskets for the valve covers and the oil pan.
Should I lubricate them with engine oil (like the O-ring on an oil-filter), or also apply RTV to make sure they're tight.
Thanks.
Old Mar 21, 2010 | 04:12 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: Gasket questions
I'd only use the locktite stuff if you have pitting/uneven surfaces
For 20+ years I've only used a gasket and this stuff
http://www.permatex.com/products/Aut..._Sealant_a.htm
Make sure both surfaces are clean, smooth and dry
A wet finger will find any leftover gasket or crud
And I like these gaskets
http://www.summitracing.com/search/B.../?autoview=sku
But any paper gasket that comes with the pump will do
Old Mar 21, 2010 | 04:15 PM
Gregzz4's Avatar
BTW.....meant to say
The Permatex stuff will be easier to deal with if you ever pull it apart again
Old Mar 21, 2010 | 04:17 PM
Gregzz4's Avatar
Don't use the RTV on the waterpump bolts
Buff the threads and use either anti- or never-sieze
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
