PICKUP COIL REMOVAL HELP!
Old Mar 23, 2010 | 08:44 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
my pickup coil is bad and i have heard that i will need a press to remove the stator to get to the pickup coil. what tool will i need to do this? and is there any tricks to this? thanks for the help in advance
Old Mar 24, 2010 | 04:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: PICKUP COIL REMOVAL HELP!
There's a pin at the bottom of the shaft that you can press out. Pressing it out removes the drive gear allowing you to pull the whole shaft out of the housing. Once that's done, the pu coil is a breeze to remove.
Old Mar 24, 2010 | 09:18 PM
Car: 1990 Trans Am
i got the distributor apart and replaced the pickup coil and now i have no spark. i checked the resistance of the pickup before and it was ok and now the coil is open according to the multimeter. i have a new pickup that i am going to install tomorrow. what can cause the coil to to short out without ever being used?
Old Mar 25, 2010 | 04:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Bad QA.
It happens.
Old Mar 25, 2010 | 04:05 PM
Car: 1990 Trans Am
i got the car to run but now i have an intermittent no start. i replaced the module also. i checked the coil wires and plug and all are right. when it does run i have a bad misfire on cyl. 8. i have spark when it doesnt start. fuel pressure is 45 psi with key on and 35 when running i am stumped do you know of anything else that i can check?
morrow
Jan 13, 2024 12:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
mddaniel
Sep 8, 2015 05:16 PM
Winchester1094
Aug 18, 2015 10:23 AM
3rdgenparts
Aug 8, 2015 07:09 PM
