Coolant Boiling in the overflow bottle
Old Mar 24, 2010 | 04:54 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Hey guys I've got coolant boiling in my overflow bottle. I'm suspecting one of two things. Either the Thermostat, or the rad cap is not pressurizing. My temp gauge reads in the 100-200 range, and running for five-ten min at idle before it boils. I know I don't have an internal problem as there is no steam coming out the tail pipes, oil is clean, coolant is clean.
Other than those two minor things is there anything else that could cause this?
I forgot I should mention that my fan doesn't come on over the course of those 5-10 minutes. I'm wondering if the fan might be part of the problem or is it just not at the point where it would come on yet.
Old Mar 24, 2010 | 05:12 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Coolant Boiling in the overflow bottle
you only need to post in one of the catagories, no need to post the same question in multiple catagories, I responded to the one in the cooling section already. hope it helps.
Old Mar 24, 2010 | 05:19 PM
L695speed's Avatar
Sorry about that. Wasn't sure if I would get a faster response on one or the other. Thanks now if one of the mods could lock this one that would be great.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
