Fuel Problem???
Old Mar 27, 2010 | 01:25 PM
haoulie's Avatar
Car: 84 Z28
Engine: 305 H.O.
Fuel Problem???
I installed an aftermarket cam. I had a stock converted to carburated 84 Camaro. The engine code is from a 91 Firebird, but the internals were changed at some point and seem to be from an 86 or earlier. (flat tappet cam, non-roller) So I just put in another flat tappet cam, not my first choice, but since I am unemployed I was trying to do a cheap upgrade. Anyway, here is the new cam and I am not sure what information you need. Max Lift 107* ATDC and 117* at BTDC. Duration 204* - 214*. I cannot keep it idleing. When I pump the gas, I can keep it running, but once I stop pumping to gas it will stall. Even if I hold it steady at like 3000 rpm, it will just stall if I am not manually pumping the gas. I still have the stock fuel pump (mechanical) and someone mentioned that I may need a larger fuel pump. Before I invest in one, probably electrical, I wanted to check on here and see what you guys thought. Thanks in advance for the replies!!!!
Old Mar 28, 2010 | 11:11 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Re: Fuel Problem???
what carb are you running?
Old Mar 29, 2010 | 10:23 AM
haoulie's Avatar
Car: 84 Z28
Engine: 305 H.O.
Re: Fuel Problem???
It is a Edelbrock 750cfm. A little big for the car. I got the fuel problem worked out. Took off the line to the carb and cranked it over to see if the pump was pumping, and it was. I needed to back off the fuel air mixture screws and it idled. Guess I wasn't thinking.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
