ok don't shoot me but what would be safe..
Old Mar 27, 2010 | 04:07 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
My cars valve seals are going. I have the imfamous blue smoke issue. I don't have the cash right now to replace the seals,i'm trying to get everything in order to pass inspection. Could I put thicker oil into the engine? That was an old trick that atleast buys you some time. Is 20w 50 to thick or should I go with 10w40..there is 10w 30 in it now.. I WILL fix this right but like I said just buying about 1 month.
Old Mar 27, 2010 | 04:29 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: ok don't shoot me but what would be safe..
20w 50 would probably do it, but I can't recommend that. If you can't afford valve seals, then you probably can't afford the fuel to get to the testing station. When I did my seals, I got 16 umbrella seals for about $2.50.
Old Mar 27, 2010 | 04:36 PM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
wow..really? I saw a feltpro kit that has all the seal and valve cover gaskets and etc for around 250 bucks...I had no idea they were so cheap..could you send me a link or something so I know I'm getting the correct ones..motor is a 305 TPI 1987 center bolt valve covers.
Old Mar 27, 2010 | 05:08 PM
84Z28406's Avatar
I just went to the local parts store and asked for 16 umbrella seals for a 305, and a pair of valve cover gaskets. The valve cover gaskets are 10 or 20.
Old Mar 27, 2010 | 08:20 PM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
ok sounds good..now one more dumb question..since its an unbrella seal does it go over the original one?Just slide it down the valve and tighten everything up?
Old Mar 27, 2010 | 08:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the heads on the engine, you need some tools to replace/install valve seals.
You need some way to keep the valve from dropping down. The most common way is with a fitting in the spark plug hole and compressed air. Some people have had luck using rope in through the hole.
You then need to compress the valve spring to remove the keepers and retainer so that the valve springs can be removed. That's why you need some way to keep the valve in place. Once the springs are removed, you can replace the valve seals.
Parts are cheap. Tools and the time to do it can get expensive depending on your mechanical ability.
Technically only the intake valves need the seals. Oil can't get sucked into the cylinder past the exhaust guide.
Old Mar 27, 2010 | 08:59 PM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
ok so fill the cylinder full of air,bring engine around to TDC and follow firing order..then set valve lashing when all done..Does that sound about right?I was told also a clothpin just incase the compressor takes a **** or breaker trips..I guess that would be cheap insurance.
Old Mar 27, 2010 | 09:05 PM
82 Pace z28's Avatar
Car: 82 Z28 Pace Car Edition restoration
Engine: 5.7l
Transmission: t56
Axle/Gears: 3.23 open drum (not 4 long)
You got it! Apply air to cylinder once at TDC of the desired one. Use your compression tester (but be sure to remove the valve core in the end before using). You can thread a nipple on that matches that of your compressor.
Use the better "posi" seals instead of the cheaper umbrella seals. They provide a much better seal.
Old Mar 27, 2010 | 09:24 PM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
ok thanks..I Love this Forum alot of knowledge quickly.You all are a big help..Oh as a side note I have 2 little girls a 4 and a 7 year old.I took them to get there hair cut tonight.I was listening to my 7 yr old talking to the hair dresser.She was like yea my Dad had a GTO and just sold it,now he has a camaro that was in a fire but I like riding in it anyway it sounds mean and its fast...Thats my girl!..hey thats security to the hobby we all love,teaching the younger generation.
Frozer!!!
Jan 19, 2024 04:55 PM
bjpotter
Jan 22, 2019 12:27 PM
djmarch
Aug 19, 2015 12:07 PM
IrocZ'85
Aug 17, 2015 06:24 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
