AFR #1034 Self Aligning or NSA?
Old Mar 30, 2010 | 09:30 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just purchased a set of AFR #1034 cylinder heads for my engine build. Will I need to use self aligning or non self aligning rocker arms? The heads do have guide plates, so does that mean that I need non self aligning?
Old Mar 30, 2010 | 11:44 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: AFR #1034 Self Aligning or NSA?
Yes for shure non self align. Im in the same boat I just bought a set of 1041 195 eliminator's and just last year I bought a new set of self align roller rockers and now I have to turn right around and buy another set of the non self align's lol. I called AFR and they said as well you have to use non self aligns. Now the paper work that came with my heads has a section where it says "If using self aligning rockers remove the guide plates and replace with a hardednd head blot washer" but it has a big X through it. For some reson they must have found that that dosent work as well as the guide plates and now you just have to use guide plates only.
Old Mar 30, 2010 | 01:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Make sure you have hardened push rods that are designed for guide plates.
Old Mar 30, 2010 | 01:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
OK, thanks for the help.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
89 formula TPI
Sep 20, 2015 10:54 AM
