How to change feul filter?
Old Mar 31, 2010 | 09:06 PM
SSZ2891's Avatar
Yeah this is prob a stupid question but i have never replaced a fuel filter before. I have a 1990 camaro rs 305 tbi.
Old Mar 31, 2010 | 10:38 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How to change feul filter?
it's under the floor pan, under the back seat on the driver's side. Be careful, there is fuel in it at all times, and if the car has been driven in the last month, the fuel in the filter is still under pressure.
Just grab your hand tools and have at it. This is an easy job, just don't get any gas in your eyes.
Old Mar 31, 2010 | 10:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the only stupid/dumb question is the one that is not asked . soak all fittings/clamps with wd-40 or your choice of penatrent . use a couple of wrench's , do not twist the lines . you will get some gas in your armpit's , hold filter with 1 wrench loosen fuel line from filter with another wrench . when they are all loose . remove clamp , replace filter . good luck .
Old Mar 31, 2010 | 11:28 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
when i did mine i took off my gas cap, dono if that helped or not ,
Old Apr 1, 2010 | 09:23 AM
SSZ2891's Avatar
anyway to release pressure or is it not that big of a deal if there is still pressure in the lines?
Old Apr 1, 2010 | 10:03 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
It's no big deal if there is pressure in the lines. Just loosen the fittings slowly and be aware that some fuel may spray out but only for a second. The main thing is just watch your eyes. This is about a 10 min. job tops.
Infested
May 22, 2018 11:56 PM
maroe624
Apr 16, 2017 08:29 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Thornburg
Aug 25, 2015 01:46 AM
